Four isn’t enough!.. I know that sounds crazy but where we live, I have 99 channels found in a channel scan. The result of that is MANY more possible things to record and watch at a later date. Several times, I have run out of tuners. I know I could add a second Tablo and that made me think it would be neat if a second (or more!) Tablo(s) could be added as a “slave” to the master. That is to say the system would look as one BIG Tablo… in the case of two Quads, 8 possible recordings at once. That would make the user interface much more “user friendly” in my opinion.
To me, that would be much better than having to switch Tablo’s to record or watch.
Steve,
My tool (APLTablo) allows you to manage multiple Tablos in a single interface…it doesn’t allow you to tell it to record 8 things at once, but if you tell it to record on one and you see it as a conflict, right on the same screen, you can tell it to record on the other Tablo without any issues
The funny thing about your post is that my wife and I spent over 20 years working on database software. Some of which was at IBM working on active/active, active/secondary, and dual active database software.
Where is the software that provides the unified view? Maybe it done by magic.
