It would be nice to know when a show is getting close to being deleted (within a week) . Maybe a color badge, outline or something.
Auto-deletion is based on how much hard drive space you have left. Impossible to know WHEN time wise your deletion will occur as that depends on actual recordings filling your drive.
@thesillyrabbit - If you have recordings you want to save, you can choose to protect them.
@luker. I understand that. The thing is I have a 500 gig drive that’s already filled up. I don’t mind letting Tablo delete things as they get old. I would just like to know when things are due up to get deleted.
Point taken! Tx for your feedback :)
Yea I agree … a “death row” view of shows next on the choping block would be handy util you get the “keep XX shows on a per episode level” working (hint hint nudge nudge)
Perhaps an easy way to solve this would be to add a sort function to the Recordings view. You would simply sort your recordings by date to put the oldest TV shows/movies at the bottom (or top) of the list. Since the TV show episodes are grouped by show title, you would need to select them individually and scroll down the list of episodes to choose which ones to protect or delete.
The true solution is to allow for a limit to be set on series recordings.
@stolicow - That’s still on the to-do list! We were just busy working on three new interfaces the last little while :)
