I have (2) Tablos. They worked perfectly without any issue until I think the last update. Now one of them when I pick something on the guide (live view) it allows me to pick it and then just goes back to the guide. I can’t access anything on the live guide.
Neither of them will stay connected, I will be watching something and then it looses connection, I end up power cycling both of them for the above problems and that doesn’t fix either one of them.
I have my old TIVOs right beside them and they seem to work as they always did.
Anyone elese having any issues with your Tablos? I am not sure what happened but they seem to be near worthless now since they don’t work.
They went from perfect to not even functioning.
Since I have two and they both have similar issues…that is what I think it was a firmware update the corrupted both of them?
Any thoughts or opinions?
TIA.
