Is it possible to
sort recorded episodes by record date. I use a Nexus Player to play back the recordings and Logitech Harmony Hub remote to control it all.
I don’t have a Nexus Player, but you should be able to select “Most Recent” in the Recordings submenu to view the recordings from the most recently recorded to the oldest.
Yes, you just go to the recordings tab, then just hit left on the directional pad on your logitech remote, and it will bring up filters, scroll down to most recent and hit enter. This will give you what you are looking for.
Thanks guys. It works out that I go to the tv show and press the play/hold button for a couple of second or 2 and it plays the latest recording.
