iPhone app not connecting since last update - RESOLVED
Been busy with other stuff, so really never took time to how this last update was faring on in my iPhone.  Well, it’s not working apparently as it just keeps trying to connect or sync.  Is it possible to get the previous version to this update back on my tablo?
-Rodger
App works fine on iPhone 6. Delete the app, reboot and re-install.
I can try that, but I have an iPhone 4.  We’ll see.
-Rodger
I am running iOS 8.2.
What are you running?
They quit updating the iPhone @ 7.1.2.
I just did at disconnect in the Tablo app.  Shows as new Tablo, so it’s connected and scanning.  Might be all it needed since the update.
-Rodger
You mean connected and syncing?
Well the “scanning” finished and the sync is good now, HA!  Also, found my router had only 1 of the requested ports forwarded, so fixed that to.
Good, it’s working again!
-Rodger
