Just wanted to give everyone a heads up. Don’t install the iOS 11 public beta if you use your iPad for Tablo. App doesn’t launch completely. Gets stuck at “Syncing” screen. I’m sure it will be sorted by the public release. Such are the dangers of running an os beta.
Confirmed. I experienced the very same thing.
tvOS 11 beta also messes up scrolling and thumbnails in several other apps. I manually downgraded to tvOS 10 to restore peace in the family.
