I am setting up a new tablo quad and I am seeing 2 issues.
First Issue, I have a 2TB drive connected to the USB and on initial boot up it said that I needed to format so I did, however, now it shows no storage connected.
second issue, I see my channels on the guide, but when I go to live tv to play it is telling me that no tuners are available.
You might try a different player and see if you get the same results. I have seen occasions where my Amazon Fire Stick would say no storage available but the application on the computer showed it correctly.
Yes the tuners finally started working, but I still see no storage connected.
I have reseated the drive and restarted the Table. It was able to see it at first to ask about formatting it. I said yes to that and now it doesn’t see it.
Hmmmm, you might try reformatting the drive in windows (NTFS) and then reconnecting it to the Tablo to force a reformat. I have had to do that before to get it to work.
I did the NTFS format, now when I boot up the Tablo with the drive connected, it sees it but says it must be formatted. Once I have the Tablo format it then it no longer appears and the Tablo says no storage is connected.
