I use my iPad to communicate with Tablo. About a day ago, when I tried to connect to Tablo nothing would load: No TV Guide, only a few Prime TV shows, No old recordings. I rebooted the Tablo a couple of times, rebooted my router, and rebooted my iPad. In the settings it says that my Guide is updating. Any one have any suggestions.
I take it that I should be getting this fix soon, maybe today?
Yep - there’s a new update making its way through the app store but you can fix it by deleting the app and doing a re-synch right now.
I had a similar issue with my iPhone 7+. Try deleting Tablo app from your iPad and then reinstall it. This should correct the problem
The update from the App Store did it and all is working fine now… Thanks for your help.
