I’m using a HDMI Tablo with a 2TB external drive. But it seems that if I change anything, change a channel, change to “recorded”, anything in which there is a change, I must patiently enjoy the circular time icon ‘show’. Am I the only one experiencing this?
I would go into the settings of the Tablo and check how programs are recorded and/or live displayed. If the setting are higher then the recommended settings I would change them to the recommended settings. If they are at the recommended settings I would lower them a notch. See if that works. It worked for me. Can always change them back.
