Started about a week ago, no amount of refresh loads s complete local schedule. Really makes it hard to do much recording. What is as bad is that if a scheduled recording comes along on a blank channel schedule all the future recordings go stale. When/if the channel schedule comes back you have to redo the recording schedule manually. Otherwise, no recording.
@Falcon67 Sorry to hear you’re running into this.
From what you describe, it sounds like some of your channels have zero guide data but others DO have full guide data?
Do you have a subscription or no?
And in your settings screen, when does it say your guide was last updated?
We have a subscription and I’ve manually made the Tablo update the schedule more than once. My have all of channel 9.1 (NBC), some of 9.2, none of 9.3 or 9.4, none of 12.1 (ABC), etc. Hit or miss.
Hrm… That is quite odd.
Can you place a ticket with support with specific details (i.e. which channels are totally missing, which are partially missing, as well as your Tablo’s MAC address)? www.tablotv.com/ask-tablo
That way we can do some further investigation on our end.
I’ll do that when I get home later- thanks.
