Happy to help!
Is there a way to bring in 2 markets to the guide? My antenna pulls in both Cincinnati and Dayton but I have to choose one or the other for the Tablo and the guide.
If the 2 markets broadcast on different channels, you might be able to get the channels to list correctly in the guide by changing your zip code (Tablo Settings). If they are on the same channel, I don’t think it is possible.
I have a similar problem. I live in Connecticut, but I can get channels from RI and Boston, MA. When I used the zip code from my town, Tablo listed a lot of channels incorrectly because they thought they were coming from a different DMA. I had to change my zip code so that Tablo got the guide data from the correct DMA. I had to compromise. There is no zip code that will work for all of my channels. I settled on the zip code that worked for the channels that I watched the most. By changing zip codes, I now get correct program guide data for both the Hartford CT and Providence RI channels.
Sounds like a 2nd Tablo or similar device might be an option. That’d probably require another antenna too.
My guide for my zip code is completely off, i am in the NYC broadcast area, as a work around i was able to submit a different zip code then mine, it gets most of the channels correct. when will zip codes getting the correct channel line up be corrected?
It seems the guide is getting worse instead of better. This makes it impossible to record on these channels. It kind of makes a person believe there is a conspiracy to force a person to watch the ads on these channels. Two of these channels have no guide info so I can’t even put them in my FAVORITES. Three other channels have guide info for other channels. I have reported this to Tablo but nothing has been done. Does anybody have any ideas on how to correct this. It makes a fellow wonder if they knew that the guide would not be maintained and went with no charge for the guide for that reason.
