Improve management of listings
So the NFL wildcard game on Fox today is listed at the wrong time. I have been unsuccessful in getting the Tablo guide to update the time despite following the guidance online to clear cache (really delete the app over and over) and/or rescan channels using AppleTV/Roku/various iOS devices. It is possible the issue is actually with Gracenote.
It would be helpful if Tablo would implement improved management of the guide including:
  1. Add ability to easily clear/refresh guide data for 1 channel at a time.
  2. Add ability to confirm data for any channel against gracenote entry baseline and report a listing issue to gracenote/Tablo right from Tablo app.
Sometimes it’s Gracenote sometimes (more) it’s Tablo.
Here’s the Gracenote TV listings. Just change it to your zip code… To see if they match.
The re-scan/save seems to work best when you use a zip code adjacent to yours. It replaces the data completely. I rotate zips to correct errors that accumulate.
https://tvlistings.gracenote.com/grid-affiliates.html?aid=cha
CST
Thanks much for the input - I had not tried to change the location. Unfortunately changing location did not work either and my channel guide is still stubbornly showing college basketball instead of the NFL game which was incorrectly listed as appearing on FOX at 1pm Eastern.
Same issue here. The guide showing on both my android phone in Tablo and on my LG tv show basketball for the 4:30 PM slot today. But I clicked on the FOX 29.1 in the left hand column on the guide and it brought up the Eagles game starting on time.
In another thread people are reporting other instances of the time being wrong also.
