I can record 24 hours of a channel for 1 month?
@albertodaniel - Not sure what your use case is, but you would have to create six 4 hour manual recordings per day to capture everything. And then at 720p you would need to add a fresh hard drive about 2 weeks in.
It is technically possible, but if you touch base with @TabloSupport and give us more details about what you’re trying to accomplish we may be able to suggest a setup to suit your needs.
It looks like on the manual recording setup that you can set a max of 1440 minutes, which is 24 hours. Is there a problem if you set a manual recording greater than 4 hours?
@snowcat - The firmware is just a lot happier if you set smaller chunks. Like many systems it’s easier to move/change smaller files than gigantic ones.
