Could the webmaster kindly allow my browser access to its own controls.
I can’t get to my android Chrome, back/fw/Urlacher bar/ or close the tab. I can only kill Chrome to exit the forum. If on restart, I can’t jump to another tab that is not this forum, I will need to Uninstall chrome or delete the user data, which will obliterate my current working tabs and take time.
On revisit here, likely, disable Javascript, but will break forum.
The first mistake is using Javascript. Javascript slows page load, a security risk, and bars the user from their own controls and layout. Totally forgetting that a browser is a user agent, never an author agent. So, nonsense like the disintegrating page into ads 30 seconds after load, should not be possible. Also, page load time under 400 ms should be the bar to meet. Not 2 seconds, not 4, not 8.
