How to setup seagate portable storage
Waiting for Chapter 1…
Thanks for the info.
So, let’s say the OP was a question. In short, you simply plug in the USB drive into your Tablo (talking the standard devices, not the Shield capture device). Tablo will format the device for use with it.
Given that a user is using an app listed for initial setup aren’t there at least 5 states where a new disk could be attached and thus need formatting:
Power up with new disk attached
reset with new disk attached
factory reset with new disk attached
powered up without disk attached - attach new disk
powered up with old disk - unplug old disk plug in the new disk.
Thank you
Welcome
