How do i update my tablo
Hello,
Every time I connect to my Tablo via Roku it comes up that my Tablo needs to be updated with Ipad, Google Chrome etc…What is this and how do I do the update?
Thanks
Everything that you can watch Tablo on, with the exception of Roku can upgrade the Tablo. What device did you use when you first set it up? Use that device or another and the Tablo app for that device. It will tell you it needs to be updated and there will be a button to press.
