For future reference, I would check my smartphone, tablet, computer, or any other device that connected to that router to find out what its SSID was.
If Gerry was really giving solid advice and for reference to the further future - at the top of every page tablotv.com there’s a search box – there’s also a header with a link for Support
There you’ll find a button taking you to Welcome to the Tablo Knowledge Base – Tablo just enter change wifi into the search box.
You could have saved some struggles and an unnecessary factory reset…
They really do make it that easy to figure things out
