I’m trying to implement a Tablo client in node (why…if interested read below). I successfully get to the final api:session/connect request for a registered connection, but never receive a response. I haven’t been able to figure out what I’m doing wrong.
The documentation indicated the signature isn’t used. I’ve tried it with a dummy value and I believe one created correctly and yield the same results. I successfully get past the guest login and see the auth server hit. I’m not sure if any of the values in the messaging should be shared, so I haven’t posted here. I am happy to share on a PM (me@jimrush.net).
Any suggestions on what might be wrong or where to look?
As for use case: I’ve been slowly building up a home automation system on a Raspberry PI. Key components are OpenHab with ZWave, Amazon Echos, Slack interface, eMail interface. I would like to expose scheduling information and actions on the various interfaces.
