HD Home Run and Table ENGINE
I purchased an Nvidia Shield as a replacement for my Nexus Player and I’m going to utilize either the Plex DVR service or Tablo ENGINE as an OTA DVR. I’d rather buy and HD HomeRun product since I feel this gives you better options down the road, but it looks like the Tablo ENGINE only supports their tuner or Hauppauge’s option.
Does anyone know if the Tablo ENGINE will be updated to support HD HomeRun products or if the Tablo ENGINE already works with HD HomeRun?
Thanks!
It does NOT work with the SD/HDHR products. I can’t imagine they would support that in the future either as they are a direct competitor.
