@ChrisFix, I have opened and replace drives in both the Tivo's I have, both were single drives. So what Tivo are you speaking of?
Any Tivo you add an external drive (DVR Expander):
@ChrisFix I am pretty sure that is just used as extra storage, not the way Tablo was talking about using splitting across the two.
Not sure. Â From Tivo:
@ChrisFix, yikes I did not know that, but again that would be an issue if you have one drive go out you lose all your recordings then⌠That is bad
Yes, that is my recolection of how it worked. Â My old (and I mean 10 or so years ago) Time Warner Cable DVR worked exactly this way as well. Â It had an eSATA port that accepted pretty much any drive, but once paired, removing it reformatted the internal drive and all recordings to date were gone.
I formatted my hard drive using Tablo but now I need my hard drive back. Is there anyway I can reformat it back to where I can use it with my PC?
Yes plug it into your computer and then go to Disk Management, accessible from the Control Panel.
You should be able to delete the partition and create a new one that a PC can see.
@criscruz In Windows Explorer (the folder icon) right click on My Computer (âThis PCâ in Windows 8) and click on Manage. In the popup window click on Disk Management. In the lower half of the next screen find the disk with no drive letter. Right click on that drive and click delete volume. Make darn sure it has no drive letter before deleting the volume, it will erase everything on the drive. Right click on it again and click create simple volume. The next series of screens will walk you through formatting the drive and assigning a drive letter.
Same problem same Seagate, same that I canât return it. But now itâs December. Very annoying to still see this problem! What am I supposed to do
Well, for one thing I wouldnât cross post everywhere (maybe you just did it once). Anyway, since you did it, make sure update this thread as well. Thanks.
Yes I posted twice, because my device was not doing what it was supposed to do and what everyone said it should immediately intervene to do, which is ask to format my drive. Thankfully it does seem to have needed an hour to decide to do this, as it suddenly decided to format my drive after an hour of no intervention on my part.
@jestep - re: your fear of using more than one drive: Having >1 drive is usually better in terms of performance OR data protection. Typically this is done using âRAIDâ (Random Array of Individual Disks - hereâs a wikipedia link: https://en.wikipedia.org/wiki/Standard_RAID_levels - or do an internet search.) Youâll find that there are only 2 options if you only have 2 drive sets - RAID-0 or RAID-1. Depending on how Tablo implements the drive array, having >1 drive can either allow for MUCH faster writing (RAID-0 - striping) which can significantly improve ability to view and/or record >1 show at the same time OR can provide data redundancy (protecting you against failure of one of the two drives - e.g. RAID 1 - mirroring). Loss of your drive when you have only a single drive will ALWAYS cause you to lose data, so itâs usually better to have two for one of the reasons already noted. All said and done, I wouldnât be afraid of >1 drive - Iâd typically be in favor of it. However you end up going, be sure to buy a quality drive (or drives) from a reputable vendor, with the highest read and write speeds that you can afford. (Usually a higher SPINDLE speed is indicative of faster read/write for rotating media. Youâll have to do your homework if you choose SSD - they have their own bottlenecks and some are much faster than others). Hope this helps.
LOL, I have been in IT for 20+ years. I know all of this.But thanks
Nothing like resurrecting a thread and replying to ancient posts!
@bstax, with said, there is yet another âwayâ and that is via concatenation. Where two block devices are merely spanned and treated as a logical single drive (no raid, no âraid0â).
