Getting a lot of weak signal warnings all of a sudden. Could my drive be failing?
Hey mate, someone else posted about this symptom, so maybe yes. They had a bad usb wire (which they replaced), so maybe first try replugging that in case it was not in tight.
@Richard_Rousselot Do the errors stop if you remove the drive & try live TV?
Send a note to our support team; we can check your Tablo’s logs.
