This has been going on for a while now…probably since the last firmware update.
My guide status will not update automatically. Pretty sure it used to do that???
But, if I don’t go in and update the guide status at least once each day, then Tablo just doesn’t record the shows I have set to record.
Please tell me there’s a fix for this.
Can you please touch base with Tablo Support? They’ll be able to fix this up for you:
