My guide that is displayed on my Roku tv is not showing the right side only shows left side. I can see only the stations not what is on right now. I have tried everything but nothing fixes it. It was working a few days ago.
Reboot your router, then reboot your Tablo, then reboot your Roku.
Thank you so much it worked. I have been talking with support on Tablo and they haven’t even been able to fix it. Pretty sad when it’s their product. Thanks again.
The screenshot of the app you sent to our team is not the Tablo app - you appear to be using a different application which is likely what caused the confusion in our attempts to troubleshoot. Glad to hear the app you’re using is up and running!
