I bought a two tuner Tablo a few weeks ago and out grew it very fast so I exchanged it for a four tuner.
Here’s where the problem came to light, with the two tuner model I had guide information for 32-1 YESTV-H, with the four tuner I don’t. I can tune to the channel without problems.
I setup both tuners the same way by entering my postal code.
Any suggestions? I’ve tried reloading the guide numerous times with no success.
I had the same problem with that channel and I did a postal code closer to Hamilton and it worked fine. This was for 36-1 though. If you are indeed talking about 32-1 from what I can see that is YesTV in calgary so you’d want to pick a postal code closer to there
