Guide Incorrect for Philly Channel 28-3 Quest
In the Philly and surrounding areas Channel 28-1 = WFPA = Unimas, 28-2 = GetTV, and 28-3 was Grit but for many weeks is now Quest. I have rescanned multiple time in the last few days and while the tablo quad now correctly shows 28-3 as Quest the guide info remains the same as Grit… which is incorrect.
Ask the Tablo Team | Over The Air (OTA) DVR | Tablo you’ll have to contact tablo support directly… they can’t fix it from here, nor is there much of anything can be done… no matter how many times you re-scan
