When I load channels one of them is showing data from a different channel. (Heroes channel shows the data from CBS). When I go to live tv the correct shows are playing but because the guide is incorrect it is more difficult to record. And when I record a show the icon shows the incorrect program.
Submit a support ticket with the actual channel call signs, channel numbers, and your zip code. That’s what Tablo support needs to get their guide provider to fix it.
