Hey @TabloTV or @TabloSupport
Ok, update, just refreshed my browser and it was at 55% and seems to be updating. But still, I shouldn’t have to do it manually.
@Jestep Hm, that’s weird. I’ll chat with the engineers and inquire why your Tablo didn’t get its guide update.
How often is the Guide supposed to update?
Once a day, usually early in the morning (1 AM or so)
My guide never updates on it’s own. I have to manually update it. Is there a setting I’m missing?
You may just want to try rebooting the Tablo. It should always update every morning. If rebooting doesn’t help, open a ticket with the support folks.
@Frelayfoto
That may be the issue then. I have the Tablo along with my TV on a timer. Everything shuts off at about 11pm and back on again at 10am Pacific time. What time does the guide update?
@TabloSupport, this may be another feature request. If I or @fraleyfoto in this case, turn everything off at night Tablo should be smart enough to know hey I have not updated guide info in x number of days so try again. And then send a notification if I can’t
@Jestep Will pass this along
@fraleyfoto, it updates around 3 AM to 4 AM in my time zone (CDT), and I am pretty sure it does it the same for each time zone.
@fraleyfoto Woops - I didn’t see your post!
I have been having some glitchy issues, but contributed that to the new ios. I will plug it into direct power. Thanks.
Last week I had two nights of recordings not record. I realized that the guide had not updated during those two days, and because I do not subscribe to a guide and only get 24 hours of free guide at a time, the guide goes completely blank if it doesn't update. That would explain why the recordings did not record, I guess? Once I manually updated the guide it resumed working, but I have been checking daily to make sure the guide is updating. This makes me nervous if I ever have to go out of town and can't check the guide updates. What if it doesn't update and nothing records while I'm away? I have never unplugged the Tablo since setting it up. The only thing different during those two days is that I was very busy and never used the live tv stream or watched anything that was previously recorded. Is it possible it didn't update because I did not use it at all? But I did access the app on my ipad to set up the recordings during that time. I know they were set up correctly because I set them to recur weekly and they still showed up in my recording schedule even though nothing recorded. Hopefully, it was just a one-time glitch, but I will post here if it happens again.
@dvras - contact the support about the problems. Unless your signal receiption is iffy, that doesn’t seem quite right.
@dvras If this does crop up again, let me know ASAP and we can check your Tablo’s logs to see what’s going on.
