I’ve been having trouble during rain events receiving a particular channel, 13-2, named “K5”, for which I’ve always received a correct guide.
I also see “K5” on channel 6-1 from a different source. If I discover it with a channel search, and select it for display in the guide, I don’t see any channel information.
I would like the guide to update 6-1 to the same information provided for 13-2.
Unselecting 13-2 doesn’t cause this to occur, nor does scanning for new channels, selecting 6-1, and then updating the guide.
Is this a guide problem, or a Tablo software issue?
Well, after doing the channel scan a second time, saving that scan, and then doing a manual guide update, the guide information is now showing on 6-1.
Is there a restriction to the number of channels with the same information that can be displayed at any given time? Is their some subtlety on how this works that I missed?
