Google app on Android phones
If you have an Android phone and Google app not working, uninstall the updates and it will work again.
works for me :confused:
Mine works after uninstalling the updates. If you google you’ll find others with the problem. Might have to do with version of Android. Since i have Galaxy S7 it has the latest released version.
This is definitely the most random post I have ever seen on this forum…
