Have new fire sticks and a new Tablo. The app is downloaded on the Firestone and is set up. But when I search for a device nothing happens.
@TRAE_F Have you set the Tablo up as well? (Gone through the setup steps in the quick start guide that came with your Tablo?)
If not, you’ll need to do that first.
The Fire Stick and the Tablo will also need to be connected to the same home network.
If both of those things are done, try these steps: https://support.tablotv.com/hc/en-us/articles/208223573-Troubleshooting-your-Tablo
