New owner of 4th Gen Tablo 2. I’m coming from a Mediatronix Homeworks. I definitely like the Tablo as Homeworks was missing features and had a very challenging remote. BUT, it did fast forward with images at up to x32. I’m on a 2022 LG G3 with the typical LG “magic” remote and fast forward seems very slow, either 10 seconds per click, or hold the right button down and wait. This appears to be the same speed on finished recordings(w images) or time shifted recordings(w/o images). Any tips on speeding it up or simply jumping ahead bigger steps than 10 seconds???
Best Buy has a replacement “LG” remote with << fast rewind and >>fast forward buttons. Would that work any better or does Tablo need to fix the LG interface?
I have an LG magic remote with no ff or rewind buttons. The 10 sec forward and rewind is all you’re going to get with that remote. I don’t know if you got a remote that has those functions if it would change anything. You can try but like I said I don’t know if that would get better, as that issue would be isolated to the remote. In theory with actual ff and rewind buttons would change things. I’m hoping I’m making sense as, I’ll be the first to admit, I’m not the brightest bulb in the drawer.
