Failures 127 doesn’t go away. Get blank screen when try to resolve.
Hisense Fire TV. 4th Gen. 2 tuners. 1TB drive.
Would you please provide a bit more detail as to what Failures 127 refers? Otherwise, unplug the Gen4 Tablo and plug it back in again after 30 seconds.
unplug didn’t help.
Model TDNS2B-02-CN
S/N GI-C02117766
MAC -----
6TB external disk Seagate Expansion SNNAC825JL DOM 05/2021 Model SRD0NF2 STKR6000400 PN 3EHAP2-570
Thanks
Hi @hammamis,
Would you share when you see this error?
For instance, does it happen when you’re watching live shows or recorded ones?
Does it happen with over-the-air programs or streaming ones?
How often does it happen?
Is there anything that seems to trigger the error?
I set record new for a show. After watching the first episode I set don’t record and delete all.
I got failure 127 and when I click on it the screen shows error and when I click on retry I doesn’t do anything so I click on dismiss.
We brought this up with the prodcut team. Would you be able to share a picture of this happening?
It’s now 128. I can’t tell what is failure No. 128.
Sorry you’re running into that @hammamis,
Would you share a picture of this error?
You fixed it. Thanks.
