I have a Seagate 750 GB 2.5 inch HDD in an enclosure. I’ve used it successfully as an external hard drive for several years.
Since I had it as a spare, I removed any unique data from it and connected it to the Tablo Dual 64 GB DVR Tuner that I’ve had for a couple weeks. It SEEMED to format OK, but now, each time I fire up Tablo on my FireTV Stick, it says I need to format the HDD…
I’ve done that a number of times and NOW, it just keeps giving me that message, so I disconnected the HDD. BTW, due to issues, I’ve had to restart my Tablo several times, so I thought that THIS would clear things up.
I knew that the Tablo format is different from my Win 10 format, so I connected it to two different Win 10 computers, intending to format it for Windows 10 again, and THEN reattach it to the Tablo. Well, no such luck: neither computer will recognize or find this Ext HDD, no matter what I do.
So, it seems that I’ve taken a perfectly good and working Ext HDD and ruined it with Tablo. I cannot get it to work with Tablo, nor with my Win 10 computers. I have other Ext HDDs, but no way in HELL am I willing to make them useless as well, and I do NOT want to buy a new one and ruin it.
So, what am I doing wrong?
OH, and AFAIK, nothing from my OTA signal was actually recorded onto the Ext HDD… Am I correct in assuming that the 64 GB of internal memory on the Tablo fill up first, then use an Ext HDD if one’s attached and formatted?
Help!
Thanks.
