So what happens if you just plug the tablo into the router and don’t set up port forwards? At the moment using the android app externally. The shows say how many minutes remain but it starts at the beginning. I tried actually tapping the word resume, did not make a difference.
If remote connections work at all, then the port forwards are in place. If you have uPNP enabled on the router, then the Tablo was probably able to create them automatically.
The shows always starting at the beginning is a totally different issue and is discussed in another thread. Nothing to do with port forwarding, though it might be a remote connection only bug.
Thanks. Found that thread. I set ot down because of buffering over LTE. I guess I could put it back and see how bad it gets or deal. Haven’t been doing bad with remembering where I was but Sprint LTE is alas not optimal.
