Editing wifi settings in 2.2.38 release
Quick question - feeling a bit stupid…
I have a new router/network, can anyone tell me where to find the “edit” or disconnect key in version 2.2.38
The info I found says to disconnect from tablo then click on the edit button
I assume you’re on iOS? The app has a newer version than the info you’re reading and the disconnect is in a different place. Press the icon of the Tablo picture in the upper left and then click ‘options’ next to your Tablo. You’ll see the edit wi-fi option there.
Nope - not IOS
Usually work on windows laptop, also have android tablo app
Neither will connect now
I’m thinking I need to do a factory reset???
Never mind…I think I did it.
Not sure how but it works now.
