I can log into tablo from one of my devices but can not see any of the recordings. I can set it to record but it shows nothing. However if I do to another device I can see all the shows recorded. Been this was for over a month. Any ides?
Might help if you specified which device works and which doesn’t.
You may want to remove that tablo from the device that’s having problems and re-add causing a re-sync
