I think I have discovered an undocumented feature of the Tablo device-- it is a dust and cat hair magnet that puts the swiffer rags to shame!
I live with a cat, or rather a cat has deigned to live with me! As such I am forever resigned to daily dusting in my home just to keep up with the unrelenting assault of cat hair. I have a desk in the corner of my great room (sort of a combined living room/dining room/den) which houses my equipment on a small shelf. It has a pc, an Ooma VOIP device, an Ethernet switch, a Raspberry Pi, a printer, and of course a Tablo. Each day I notice that the Tablo is covered in dust and cat hair, while the other equipment is not.
I suppose this is because the Tablo has more of an electrostatic charge on its surface. I wonder why?
Have you tried using Enddust or some other anti static electronics cleaner ? … its the plastic shell is highly attactive to things like that… you could also try gently wiping down the tablo case with a spare clothes dryer sheet.
@ddd671 - That is very much an undocumented feature… We actually spend a LONG time on finishes for the plastic to make sure that it wouldn’t look smudgy/fingerprint-y. We didn’t test with cat hair though.
Obviously your kitty is making it abundantly clear that he/she owns everything within his/her domain :D
@ericgus has a good idea with the Endust though.
@TabloTV Sorry, the geek in me is coming out. I assume your using some type of PC/ABS for your enclosure as that is the most widely used injection molded plastic in the world besides Polypropylene.
@roraniel - That is a damn good question and not one that has ever been asked. Will have to consult with our hardware guru.
@TabloTV I know the guy that developed PC/ABS at Dow Chemical if your guru wants to consult with him. I know just enough to be dangerous.
I think that the culprit is the over-the-hair tuner.
I think that the culprit is the over-the-hair tuner. ;)
@Jestep - HA! That would be hilarious!!!
@TabloTV That is what I thought. That is the PC/ABS I mentioned in my original post. They come in thousands of blends for hundreds of applications. I’m sure there is a cat hair resistant blend.
I like the Endust idea; I’ll have to give it a try.
I’ve only had the Tablo for six days, and I just cut the cable on 2/14 (turned in my hardware to Time-Warner today). So far I’m very satisfied with my Tablo and the only irritant is the lack of an AFTV app which I know is coming soon. I can’t wait.
@TabloTV Actually my cat’s favorite show is the on-screen fireplace app from Amazon. Go figure.
Wipe it with a dryer sheet.
No hairy Tablo…
+1 ShadowsPapa - Used dryer sheets are a great way to make old CRT monitors and most plastics dust/static free for at least a short period of time. All these anti dust products are the same thing but packaged to be more expensive (and less smelly).
Yes thats why I originally suggested a dryer sheet after my endust suggestion in the second post… but its nice to have options.
The Tablo runs warm. It’s winter. Your cat is cold.
My cats ignore it - treat it like it’s just another thing to walk around or step over…
No kitten (kiddin)?
Where’s that “slap forehead” and groan icon…
