Dual Antennas with Tablo
I am not even sure if this would even work or if it is supported by Tablo but here goes.  I am currently using a Mohu Sky (Attic installed) with my Tablo.  I am able to get nearly 50 channels (Canton, OH area) with no problem.  I am however having an issue getting the local Fox 8.1 HD channel to come in with a clear signal.
Prior to using the Mohu Sky I used a Mohu Leaf 50 and had no problems getting Fox 8.1 HD at all.(The leaf was installed in my 2nd floor bedroom.)
My question is would I be able to use a dual antenna setup to try and pull in Fox successfully.  Is it possible or is it even supported by Tablo?
I would feed both antennas into a 2 input - 1 output splitter and feed that to the tablo via the supplied Mohu amplifier.
Over all im loving the Tablo and I'm cancelling my cable here once I have my Tablo setup completed.
Thank you.
  This allowed for positioning antennas in two
directions for two different tower locations. Power supplies were before splitter.
 It worked well.  You must be careful where you position  power supplies and ensure there is a cable
between splitter and Tablo.  I used RCA
Gold 2-Way Coax Video Cable Splitter (4mhz-3ghz) from Lowe’s with very little
signal loss (tested with and without).  Tablo
has built in tuner, putting amplifier & power supply between the splitter
and too close to Tablo, could cause digital noise and possible damage to Tablo.  Important to note, I put a DC-block on the
single side of the splitter and between the 3’ cable before connecting to Tablo
just to be on safe side.
Bottom line, check TVFool.com and get a report to analyze reason why you may not be getting Fox channel, i.e., UHF versus VHF, distance from tower, elevation of antenna, azimuth, obstructions, etc.
<w:LatentStyles DefLockedState=“false” DefUnhideWhenUsed=“true”
DefSemiHidden=“true” DefQFormat=“false” DefPriority=“99”
LatentStyleCount=“267”>
<w:LsdException Locked=“false” Priority=“0” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Normal”/>
<w:LsdException Locked=“false” Priority=“9” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“heading 1”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 2”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 3”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 4”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 5”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 6”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 7”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 8”/>
<w:LsdException Locked=“false” Priority=“9” QFormat=“true” Name=“heading 9”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 1”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 2”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 3”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 4”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 5”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 6”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 7”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 8”/>
<w:LsdException Locked=“false” Priority=“39” Name=“toc 9”/>
<w:LsdException Locked=“false” Priority=“35” QFormat=“true” Name=“caption”/>
<w:LsdException Locked=“false” Priority=“10” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Title”/>
<w:LsdException Locked=“false” Priority=“1” Name=“Default Paragraph Font”/>
<w:LsdException Locked=“false” Priority=“11” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Subtitle”/>
<w:LsdException Locked=“false” Priority=“22” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Strong”/>
<w:LsdException Locked=“false” Priority=“20” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Emphasis”/>
<w:LsdException Locked=“false” Priority=“59” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Table Grid”/>
<w:LsdException Locked=“false” UnhideWhenUsed=“false” Name=“Placeholder Text”/>
<w:LsdException Locked=“false” Priority=“1” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“No Spacing”/>
<w:LsdException Locked=“false” Priority=“60” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Light Shading”/>
<w:LsdException Locked=“false” Priority=“61” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Light List”/>
<w:LsdException Locked=“false” Priority=“62” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Light Grid”/>
<w:LsdException Locked=“false” Priority=“63” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium Shading 1”/>
<w:LsdException Locked=“false” Priority=“64” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium Shading 2”/>
<w:LsdException Locked=“false” Priority=“65” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium List 1”/>
<w:LsdException Locked=“false” Priority=“66” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium List 2”/>
<w:LsdException Locked=“false” Priority=“67” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium Grid 1”/>
<w:LsdException Locked=“false” Priority=“68” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium Grid 2”/>
<w:LsdException Locked=“false” Priority=“69” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Medium Grid 3”/>
<w:LsdException Locked=“false” Priority=“70” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Dark List”/>
<w:LsdException Locked=“false” Priority=“71” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Colorful Shading”/>
<w:LsdException Locked=“false” Priority=“72” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Colorful List”/>
<w:LsdException Locked=“false” Priority=“73” SemiHidden=“false”
UnhideWhenUsed=“false” Name=“Colorful Grid”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 1”/>
UnhideWhenUsed=“false” Name=“Light List Accent 1”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 1”/>
<w:LsdException Locked=“false” UnhideWhenUsed=“false” Name=“Revision”/>
<w:LsdException Locked=“false” Priority=“34” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“List Paragraph”/>
<w:LsdException Locked=“false” Priority=“29” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Quote”/>
<w:LsdException Locked=“false” Priority=“30” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Intense Quote”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 1”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 1”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 1”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 1”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 1”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 1”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 2”/>
UnhideWhenUsed=“false” Name=“Light List Accent 2”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 2”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 2”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 2”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 2”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 2”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 2”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 3”/>
UnhideWhenUsed=“false” Name=“Light List Accent 3”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 3”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 3”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 3”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 3”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 3”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 3”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 4”/>
UnhideWhenUsed=“false” Name=“Light List Accent 4”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 4”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 4”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 4”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 4”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 4”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 4”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 5”/>
UnhideWhenUsed=“false” Name=“Light List Accent 5”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 5”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 5”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 5”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 5”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 5”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 5”/>
UnhideWhenUsed=“false” Name=“Light Shading Accent 6”/>
UnhideWhenUsed=“false” Name=“Light List Accent 6”/>
UnhideWhenUsed=“false” Name=“Light Grid Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium Shading 1 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium Shading 2 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium List 1 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium List 2 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium Grid 1 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium Grid 2 Accent 6”/>
UnhideWhenUsed=“false” Name=“Medium Grid 3 Accent 6”/>
UnhideWhenUsed=“false” Name=“Dark List Accent 6”/>
UnhideWhenUsed=“false” Name=“Colorful Shading Accent 6”/>
UnhideWhenUsed=“false” Name=“Colorful List Accent 6”/>
UnhideWhenUsed=“false” Name=“Colorful Grid Accent 6”/>
<w:LsdException Locked=“false” Priority=“19” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Subtle Emphasis”/>
<w:LsdException Locked=“false” Priority=“21” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Intense Emphasis”/>
<w:LsdException Locked=“false” Priority=“31” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Subtle Reference”/>
<w:LsdException Locked=“false” Priority=“32” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Intense Reference”/>
<w:LsdException Locked=“false” Priority=“33” SemiHidden=“false”
UnhideWhenUsed=“false” QFormat=“true” Name=“Book Title”/>
<w:LsdException Locked=“false” Priority=“37” Name=“Bibliography”/>
<w:LsdException Locked=“false” Priority=“39” QFormat=“true” Name=“TOC Heading”/>
</w:LatentStyles>
<![endif]–><!–[if gte mso 10]>
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
<![endif]–>
@garadius - We always recommend troubleshooting your existing antenna before getting fancy with dual antenna setups and splitters because they can cause more trouble.
Is the Fox antenna coming from a different location than your other local channels? (Where is the tower?)
Its due east of me about 21 miles away.  I have no problem reaching HD NBC/ABC which is 40 miles away to the North/North East.
Forgot to post:  TvFool link
Hrmm… If you orient in between you should be OK…
Have a gander at these blog posts and do some finagling with your antenna position to see if you can get all the channels to come in correctly:
http://www.tablotv.com/blog/position-matters--choosing-where-to-place-your-hdtv-antenna---ota-hdtv-blog-4
http://www.tablotv.com/blog/catch-the-wave---how-geography-surroundings-and-obstructions-impact-your-ota-hdtv-signal-reception---ota-blog-3
Fox “real” channel 8’s (VHF-Hi) path is 2Edge (Double edge diffraction).  Mohu Support says “the Sky attic/rooftop unit can receive signals from 60 miles for UHF and 45 miles for VHF channels with a clear line of sight”, which you do not have for Fox. Look at radar plot for channel 8 and you’ll see its closer to edge of plot.
IMHO, here are some options. Option 1: Try pulling a compass reading from where you had your original Mohu Leaf on the second floor and match it with your Mohu in attic, Option 2: try pulling a report with exact address and higher antenna height and see if you get better results for Fox, Option3: If you have two antennas to test, why not give it a try?, and Option 4:  Mohu has a good product, but sometimes you just need an antenna that has longer range with stronger dual UHF/VHF capability (if you have the space).
</w:LatentStyles>
<![endif]–>
