I live in an apartment building that doesn’t allow antennas on the roof.
Is it possible to setup a tablo at my brothers home, view and run it from my apartment?
If so, how would I set it up?
Just because you live in an apartment doesn’t mean you don’t get over the air tv reception. Especially if you have an apartment with a window facing the broadcast antennas.
Other wise “if” your brother gets good OTA reception it’s just a matter of remote connect. various devices can do remote connect to tablo. Your brothers router would have to port forward the tablo ports. And you need to pair your device at your brothers house before you take it to your apartment. Of course it’s simplier if your brother already has VPN. Then you can just VPN to his router and access tablo.
But the tablotv WEB site has info for remote connect.
Unfortunately my apartment is on the wrong side of the building and there’s another taller building next to it. Right now I’m using two indoor antennas and get most channels well, but not the best.
Yes:
It works with network connected Tablos.
Tablos that directly connect to TVs can’t do it.
