My OG 4uner last two nights has dropped connection Apple TV 4K tvos 12.1
I have to reboot tablo
Donāt hesitate to send us a ticket. We can take a look at your units on our end and see whatās up.
Ticket sent
Thanks again @TabloSupport
User error in putting In the wrong MAC address when setting up a Tablo reservation ā¦oops
There are two Mac addresses for your Tablo one Wi-Fi in one hardwired
Only run this program after you have had a ticket in and tablo support has replied because it sends a code to them exclusively after test
I had a connection issue with my Apple Airport extremeāsā¦I know they are oldā¦but have been so steady for 3 yearsā¦ I reset them to factory settings and just ran the network Diag tool App Store (routethis helps).
Everything is back up and running properly as of now. Tablo reservation and port forwarding re-done
Awaiting Tablo support response from the findings
No joy, Disconnected overnight again back in touch with supportā¦
.Wi-Fi instead of hardwired for now
Same thing disconnected overnight with Wi-Fi
************Deleted Tablo reservation and made a new reservation with correct IP and port fwd
did not disconnect overnight and hopefully all weekend
FIXED: My problem was resolved after getting a better HD antennae. All of the stations I watch have 100% signal strength, and the random Tablo reboots have stopped.
Iāve not experienced this problem after the latest software update about a month ago. Seems that itās fixed, at least for me.
Tablo support wanted me to assign a different SSID to my second (non_DHCP) router. I didnāt want to do that so I waited this out. I had no issues with any other devices on my network so I didnāt want to change everything due to the tablo.
But as noted, it seems that the update fixed the issue.
