I’m connected with Ethernet form my PC to the router and the Tablo is connected to the same router also with Ethernet.
Using Chrome on my Windows 10 desktop, it’s hit-and-miss if I can connect. Trying to watch a show, similar. I get the spinning wheel and then some minutes later this informative message
I’m at my wits end.
Fortunately I’m still paying for what used to be my “backup” plan, but now seems to be more and more my primary plan - YouTube TV.
I definitely recommend you get in touch with our team and we can see whats’ causing the issues. That said, there’s a quick test you can do to determine a few things:
Try playing these same recordings on another device + app - are the same recordings unplayable? If so, this may be an issue with the recordings themselves, or the drive they’re stored on. If they play fine, this could be a cache or browser issue, in which case we’d recommend clearing the cache on your browser as a first step.
If this doesn’t do the trick though, reach out to our team and we’ll see what’s up.
A VPN or proxy service creates a “tunnel” to put the traffic through to the internet. There are many applications that won’t recognize items on your local network when you are using those tools. It really depends upon what port(s) the proxy/VPN software tunnel…
