As Forest Gump somewhat said “merd happens”.
I have had several database problems that required remote intervention by Tablo Tech Support. I believe the TABLO OS should have a built-in in-depth database repair utility similar to the Microsoft Windows chkdsk/scandisk utilities that can be run manually as the user sees the need to do so.
I suspect Tablo Tech Support engineers run such utilities remotely when fixing my system, so why not make the procedure a local process?
It seems to me this would eliminate a lot of wasted time and energy on both sides of the border.
