Data usage question
I do not know how to ask this. Does it take the same amount of data to send an hour of media from tablo hard drive as it does to watch an hour of Netflix?
Tablo doesn’t use your ISP data. If you are on a metered plan Netflix will use way more.
Tablo streaming from the Tanlo unit to say your Roku is all over the local network, so it does not count towards to your ISP data limit. If you are curious as to what bitrate is being transferred depending on the recording quality you use, see the link below.
https://www.tablotv.com/blog/choosing-right-tablo-recording-quality/
More info from Netflix.
https://help.netflix.com/en/node/87
1080p at Netflix uses 3 GB per hour. 1080p at Tablo uses 4.6 GB per hour.
