Had my 2 tuner Tablo for a year and by far 100x better than another brand I fought with for 3 years. No missed recordings. It just works.
Issue #1) Using the Tablo App on my NVIDIA shield AND a Raspberry Pi3 running LibreElec/KODI AND my Samsung TV the volume is very low and on all devices I have to really crank up the volume and should I forget I’ve done that when going back to other apps like YouTube/Netflix/PBS… I wake up the entire house.
Might Tablo consider allowing a settings adjustment for audio level???
Issue #2) Using the latest version of LibreElec/KODI, if I use the right arrow key on my keyboard to FF, the progress bar information is correct. However, if I pause using the space bar the progress information is totally bogus: For example: I was 15+ minutes into a show and it showed 48 seconds into the show.
Issue #3: The KODI/Tablo app {3rd Party of course} does not allow you to watch a show currently being recorded while the Android {NVIDIA shield & Samsung TV} apps do albeit without showing the various scene progress images.
