My auto scan works correctly for both of the local zip codes (99362, 99324). However, the guide doesn’t populate with channel listings for two of the channels as seen here.
@TabloSupport is this something you can help with?
Thanks!
David
Thanks!
David
Hi David - Sure!
The best way to get this resolved is to place a ticket with the support team so we can track your issue and start a request with our guide provider: https://support.tablotv.com/hc/en-us/requests/new
Make sure to include your Tablo’s serial number, your preferred zip code and the channel numbers.
