I had it working, then… I’m not sure what happened. ItWill not connect to the internet. I can find it in my wireless connection list. When connecting, it says it connects “wireless” but not to the internet.
When you say you see it in the wireless connections what do you mean? If the Tablo is creating it’s own SSID(wireless access point) then that means it can’t find a WiFi connection. You will need to connect to it and enter the details of you routers connection.
