At first, I installed the Tablo wirelessly to see how it performed in that way. While it was ok, I decided I wanted to connect directly with ethernet. I did so, and some devices will find it (but they seem a little wonky) and some devices (my PC) can’t find it.
Should I just do a reset of the box? Or is there a better/easier way? I don’t have any recordings to speak of, so a reset wouldn’t be catastrophic. Thanks.
