I hate to appear as uninformed as I am, but am not sure how to connect tablo to a 5GHz channel as this is my first duel band router. It’s an ASUS rt-n66u. any help is greatly appreciated.
Dual band routers actually have two different broadcast names, one for the 2.4Ghz network and one for the 5 Ghz network. So when you setup your Tablo, have it connect to the name of the 5 Ghz network.
@Millerprm Snowcat is correct as usual! Once your router is set up, you should notice two home networks available. They should have the Ghz specified in their name (e.g Miller2.4 and Miller5.0). Connect your Tablo to the 5.0 channel and you’re good to go.
I need a t-shirt with that slogan “Snowcat is right as usual”.
I need a t-shirt with that slogan "Snowcat is right as usual". :D
Yes, yes you do. :-bd
We ALL need a t-shirt that says that… and thanks snowcat!
