Hi,
I’m having an issue where my new (today) Tablo 2-tuner drops its connection after about 5 minutes of connectivity (while still formatting the HDD). If I unplug or reset it, I can connect (and it asks to format the HDD again), but then after about 5 minutes it drops the connection and I get the error that it can’t connect via the websocket, and the infinite 5-second retry loop. The Tablo is connected via ethernet to the home network.
Could this be a HDD issue? It’s a 2TB WD MyBook I had lying around. I know the network cable is good as I’ve been running a SD HDHomeRun to a HTPC over this line for 3+ years without any issues (and upgraded to Tablo to make it more family-friendly so everything could go through the Roku). I haven’t tried the Roku app yet since the HTML5 web app keeps erroring out.
Any ideas?
Regards,
Dylan
