I’d like to see a SMART SCHEDULING option where you could select to overwrite previously recorded programs that were not recorded with Automatic Commercial Skip.
Delete the previous recording?
(but it might “remember” for a period of time as not to record duplicates, so might have to uncheck that)
If you use RECORD ALL for that series and uncheck DON’T RECORD DUPLICATES you’ll be able to do that.
Deleting the previous recording will also work.
